I've got a 2018 1500 4x4 with air ride suspension (which I love now that I've figured out all it's quirks) and the rear shocks are blown and need urgent replacing. In my rather extensive research the only company's that I've found that make "air ride specific" shocks are OEM, and Monroe. Not a...
Hi everyone, just wondering if anyone has ever looked for or found a schematic that gives the locations for the ground straps on a 4th or 5th gen Ram 1500. I’m having intermittent issues with my AS and after screwing with it I’m starting to think I have a ground problem. I’ve scoured the ‘ol...
16 ram1500 sport with air suspension
I made a mistake. I use alfaobd to write the body height (factory value). But the truck seems to have lost the leveling function. Now loading and unloading cargo can not automatically adjust the body height. And the left side of the body is an inch lower than...
I have a 2018 Ram 2500 Limited 4x4 Mega Cab with factory air suspension in the rear. I would like to keep the factory air suspension. I want just enough lift to fit 35 12.50s and have zero rubbing and no trimming. Also maybe improve on the factory air suspension. I'm aware most likely I will...
I have a 2017 Ram Rebel 1500 with air suspension a week ago my truck wouldn’t start and I got the message “Air Suspension Needs Immediate Service”. I read the posts and threads here and was preparing for a 2k + repair. Turns out it was just the battery throwing low voltage codes about 12 all...
Hey all. I'm new here. I'm sure the subject matter I'm about to ask about has been asked a thousand times. I'm sorry if this gets repetitive.
I have a 2017 Ram Rebel that has the factory air suspension in it. My truck is going to see quite a bit of time off road and I want to lift it slightly...
