I had to pull my fuel tank down to repair a small leak. After putting the tank back and trying to start the truck I now have a bigger leak coming from the quick connect fitting on the fuel pump. Is there an o-ring in there that had come out? or Does the clip need to be installed on the quick...
I had a crack in my fuel tank. I used a soldering iron to melt the crack together and JB welded the outside of the tank to make sure it doesn't leak.
Any thoughts?
