intake manifold
  1. A
    5.7 Hemi, 2011 MAP Sensor Question
    Is the MAP sensor supposed to wobble after it is fully engaged in bore after the 1/4 turn? I've been chasing a no CEL RPM fluctuation and it appears to be associated with the MAP sensor. I cleaned it and put some grease around the Oring and it ran like a champ for about 100 miles, then started...
  2. Dilligaf-23
    Extra Intake Manifold
    So I ended up with an extra Intake Manifold after my mechanic ruined my engine and had to put a new one in. I had the exhaust manifold Hemi tick from the broken bolts. I decided to extract them myself ( Thats where I messed up) and I just made things worse. I ended up wobbling out the bolt...
  3. M
    Intake replacement on 5.9
    2003 ram 5.9. Overhauled the engine last winter and replaced the heads with aftermarket stock heads. Did the UTAwesome kegger mods including their wedge installed. Very disappointed with the engines top end performance and fuel mileage. Getting around 11-12 highway at best. Needs a lot of pedal...
  4. R
    Ticking intake manifold?
    03 Dodge Ram 1500 w 4.7 engine 118,000 miles. I have a ticking noise coming from the left side of my intake manifold (verified w a stethoscope). Why would it be ticking? The truck has lost a significant amount of power and shakes a bit when I get up to about 50-55mph. This first started after a...
  5. DoubleJ
    4th Gen Parts - Stock Intake Manifold and Catch Can
    Stock 5.7l Intake Manifold was taken off a 2014 1500 with 72000 miles on it. Worked flawlessly before removed and was removed and stored with care at the beginning of Nov 2020. No visible damage to report. Includes fuel rail and injectors, as pictured. Can include stock engine cover. $150 plus...
