2013 Ram intermittent problem with gear shifter locked in park. There is a yellow plastic paddle (I call it) under the cover. Pushing it up unlocks the shifter ... question is. How deep do I have to dig to get at the source of the problem. Is it a simple lube issue, or a broken something. Any...
Hi. New here. Been scouring the forums for a solution to my exact problem To no avail.
the truck is a 2011 ram 2500 diesel with a column shifter. The shift lever solenoid will not release on its own when I step on the brake pedal. the only way I can shift it out of park is if I use the...
