transmission issues
  1. M
    Odd transmission problems 2014 ram 1500 8hp70
    I have a 2014 ram 1500 5.7 with 8hp70. When the truck is idling and in park, the digital speedometer says 1mph. Then when I put it into drive and go above 5mph it puts itself into park and stops me. I tried pulling the lever to keep it out of park and it does a similar thing where it revs up and...
  2. A
    Not accelerating when in Reverse Gear
    Hello everyone, Quick intro to my vehicle: 1997 5.2L V8 magnum with an automatic transmission (46RE) I noticed after using my truck in 4H that I was not able to accelerate while in reverse gear. On flat ground when I shift to reverse (I audibly and physically feel the gear catch) and my...
  3. B
    68RFE slow to engage reverse
    2022 Ram 3500 SRW 4x4 68RFE, 200 miles. Please share any useful thoughts... In the morning when first start the engine and select reverse the transmission is slow to engage. The engine revs, but no movement. After about 20-30 seconds it finally engages. From then on it functions normally...
  4. E
    Transmission Issue 2014 Ram 1500 Outdoorsman 3.6L V6
    Okay so as I posted in an introduction post, I just picked up a 2014 ram 1500 3.6L V6 with about 213000km (132000mi) and I seem to be having an issue with it, so I'm hoping someone here has had a similar issue or may know what to do about it. I don't know if this is where this post belongs but I...
  5. S
    Np435 wont go into first or reverse
    I got a 1989 w150 that im swapping from auto to manual. I have an np435 out of a 79 powerwagon. I rebuild the shifter tower and put new bearings and such in. However I am not able to get it into 1st gear or reverse. 2nd, 3rd, and 4th all work fine. When I try to put it into first it pops in...
  6. B
    Transmission Issues
    I'm not sure if I'm posting in the right area. I am having problems with my 2014 Ram with a 6.4 motor. I've had three transmissions put in it throughout the past two years by two separate companies, but I keep having the same issues. It keeps burning up gears and often goes into limp mode. I'm...
  7. C
    Trans temp 2013 6speed
    Hello all, this is my first post. I have a 2013 1500 4x4 with a 6 speed and I’m seeing 200+ degrees empty on the trans. I’ve seen posts about people staying considerably cooler even when towing. I’ve flushed the transmission at 110k and replace the trans solenoids and filters and atf 5k miles...
  8. Fnord
    Is it worth to buy a 2011 Ram 2500 with transmission issues?
    Hi everyone, I'm researching to buy a 2011 Ram 2500, Hemi 5.7, and there are some issues with it. Sometimes it decides to tell you it's out of gas when it's not... the seller told me it needs a new fuel sender, and the transmission lags slightly when shifted from Park to Drive or Reverse...
  9. J
    Ram 8 speed transmission issue
    So I’m kind of in a bind, so my truck has had issues for 2 months now, (2016 ram 1500 8 speed 5.7 rotary) it’s been in and out of the dealership now a lot of times. It could take miles or it could happen immediately. The transmission doesn’t feel like it’s slipping but it will shift up gears and...
  10. V
    Multiple codes popped up during an engine check
    Hello, my name is Vova and I own a Ram 1500 2014 V6 3.6L. When driving out today, I noticed my truck was shifting in a very alarming way. The rpms went up by a thousand and then down like they are supposed to, causing my truck to sort of shake forward. This was especially true for the shift from...
  11. D
    Transmission leak
    Hi, just joined. Sorry if you have had a question like this before. So I had a small leak from the transmission for over a year, from the bolt on the passenger side that bolts the extension/overdrive to the transmission, but small. The other day the car was standing after being used and there...
  12. 14Fiveseven
    Transmission Flush gone wrong?
    2014 Ram 1500 5.7 with the 8 speed trans. Decided to change out the trans fluid as my buddy got a discount on some he bought. Didnt replace the filter. Shifted through the gears. Only took me 4 quarts instead of the 9 I thought it needed. Now my troubles start. When I accelerate hard from 0-40 I...
  13. P
    Chasing down transmission faults... 2006 545RFE
    2006 5.7L Hemi with a 545RFE transmission. Had the truck since 2010, and have had the tranny rebuilt twice in the past ten years. Recently, I've been having issues with the TFPS throwing the truck into limp mode when I am accelerating up a hill. Seems to happen only at high speeds and when the...
  14. R
    Transmission slip? (zf8) 2016 rebel
    i have a 2016 Ram rebel 43k miles on it so to begin with I am hearing a whinning noise coming from transmission or torque converter not very loud but noticeable when you give it anykind of throttle underload. now for the bad i was stopped and give it 3/4 throttle hit the first 2-3 gears then got...
  15. 08RamKenny
    Transmission fluid changeAgain
    Hi folks, newbie here to the Ram forum. I’m a member of a few other forums, and have always loved the information you can get, seems like the people always seem to wanna help. Which is very cool! So thank y’all ahead of time. Anyway, here’s my dilemma. I’m the original owner of my Cool...
  16. bigbluecrew
    Trans temp
    ok so never owned a ram b4 and bought a 2011 2500 crew cab 5.7 hemi with8ft box only had 31k on it to tow my camper. I’ve towed many trailers with many vehicles but it seems like the ram trans temp is high. We just went to hershey pa over the weekend towing 9000 lbs trans temp got up to 225 a...
  17. C
    1997 dodge ram 1500 high rpm shifting..
    when driving my truck it runs and drives fine.. but when your getting on it while towing, or getting up to highway speed the rpms will just keep climbing and will redline until you let off the gas some then it will shift into the next gear, ive heard talks about shift linkage or some kind of...
  18. C
    2014 Ram 1500 Transmission temp question
    I have a 2014 Ram 1500 with the 8 speed automatic transmission. I brought it used with 32000 miles and drove it for 9 months running it up over 40000 miles. I brought it to the dealer because of harsh shifting and lagging in the transmission. I also had 3 occasions that the tranny temp spiked...
  19. D
    2011 ram transmission issues
    2011 ram Laramie 1500 with 5.7. Took my truck to a buddy who was offering “free module updating” to train his technicians with new computer tools. Dropped the truck off and they updated all the modules, picked it up and it seemed to be running a little healthier but when driving around 60-75km...
  20. D
    Transmission issues
    Hay guys I put a new automatic transmission in my truck. When you **** to drive it goes to 4th gear in manual mode and won't shift to another gear in drive. What is the problem and how to fix thanks derek
  21. Y
    Transmission shifts hard
    so I am a new owner of diesel trucks. But I’ve been around them all my life. None of the other dodges, Ford, or Chevy diesels have had transmissions shifts as bad as mine. It’s got 128,000 miles on it. But it seems like it struggles to shift into gear. Going from first to second is awful. Like...
stevenmicheal
