Hello all, hope all is well.
I have a problem maybe some of you gear heads can help me out with. I drive a 2008 Dodge Ram 1500 4x4 5.7L V8 with a 545RFE tranny.
Let me start from the beginning. Out of the blue while I was driving my truck it started slipping gears and eventually it woulde't go...
I’ve got quite a predicament. My 2017 Ram 2500 6.4 Hemi with 84k miles had the transmission go out about a month ago. Of course the powertrain warranty had expired, so I paid a good local shop to replace the transmission with a remanufactured Jasper 66RFE transmission. I picked it up two weeks...
Hello, my name is Vova and I own a Ram 1500 2014 V6 3.6L. When driving out today, I noticed my truck was shifting in a very alarming way. The rpms went up by a thousand and then down like they are supposed to, causing my truck to sort of shake forward. This was especially true for the shift from...
2006 5.7L Hemi with a 545RFE transmission. Had the truck since 2010, and have had the tranny rebuilt twice in the past ten years.
Recently, I've been having issues with the TFPS throwing the truck into limp mode when I am accelerating up a hill. Seems to happen only at high speeds and when the...
I have seen multiple posts on this issue but not seen anything definitive whether "its just the way they are" or a failure of some sort. My eco Diesel was fine for first 5-7 K miles then developed the habit of slipping and over revving when changing from 1st to 2nd initially in winter but now...
so i just got some tires to replace my worn ones, and wouldnt you guess it the person who was changin my tires around sheared off the nut so its almost flush with the wheel so it cant grab onto anything anymore.. any ideas that wont cause any damage to the wheel, and minimal/no damage to other...
Hey guys new member here. My grandfather past away several years ago and he had a 1983 dodge b250 conversion van with the 318 carbed engine. It has 33,000 actual miles on it. My grandfather never used it and basically let it sit for about 20 years. Last time it was registered was 1995. My dad...
