Hey All,
I just recently purchased a zone 4" lift with level tail end and fox shocks.. I took it to my local garage to be installed and they called me and asked if I was purposely going for the "carolina squat" :mad:... I drove up there and it definitely isnt any where close to being level in...
I didn’t see this specifically discussed anywhere, but forgive me if I overlooked it.
I have a 2020 Laramie(new body) with stock 20” wheels. I just ordered a 4” Zone lift from Nick and I’m planning on running 35x12.50R20 Discoverer ST Maxx on stock wheels. Will I need spacers with that setup...
Well I made the leap and bumped up from a 2” level to a full blown zone Offroad 6” lift with a complete fox suspension. The credit goes to @Quick_Shifter for his extreme knowledge and attention to detail on these Rams.
If you’re thinking about doing any suspension work and you want to spend...
I'm thinking about which lift kit to get for my 4WD truck and I cant seem to find any bigger than 6". I found a Zone 6" (Sister company to BDS) that you can get with a 5" coil in the back to retain factory rake. I was thinking I could pair that with Bilstein 5100 or 6112 in the front set at...
Have a question I cannot find a solid answer to after hours on the googalizer and here. I currently have the bilstein 6112 leveling kit (set to max, but I would change it with the lift) plus zones d2301 upper control arms. I'm looking to add zones 4 inch lift (plus the 3 inch springs in the...
