00 Ram 1500, Front Driver Turn Signal Issues with 4x4 Light flashing and a box under battery clicking
C
comet424
canada
in middle if making a video the rpms fixed itself... i dunno how or if it was cuz i had a dead battery yesterday.. and charged it.. but not it idles under 1000 rpms so i dunno
so its crazy why the rpms were running at 2200rpms
Spike95
Houston
Is there any rigged wiring that some previous owner has done on this truck?
I appreciate you making videos, but I think the bottom line here is that you SERIOUSLY need to look at a wiring diagram. Make multiple print outs of it and get colored pencils to trace where the affected circuits go to. Then you can start finding the points they have in common.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I read through this post quickly
May i suggest that you check the 7 pin socket for any corrosion, just a bit of corrosion between 2 pins can mess with lighting anywhere in the truck.
spray the socket with lectri-clean or other electrical contact cleaner
