BillyD1002
The truck has 87k on it. Bought it two years ago and only put about 4k on it. The trans always seemed to make a noise when put in reverse but still worked fine. Recently the trans pan was leaking a good amount (the previous owner said trans was serviced not long before my purchase) so I found some loose pan bolts and tightened them up but that seems to just destroy what was left of the soaked gasket and it started pouring out. Rather than making a mess draining and replacing my pan gasket on the near seal-coated driveway, I took it up the block to the local mechanic. I get the truck back and drove it today and started to notice it slights when it downshifts from 2nd to 1st for a second. Does anyone know what that problem could be? I hope it is not the trans getting near the end of life. Any advice would be greatly appreciated.
