MrFixIt
Every time the truck is travelling more than 5mph and I depress the brake for 4-6seconds 'dash lightning bolt' lights up as the throttle reduces airflow and the engine begins to stall. Within 2 seconds of the lighting bolt the engine dies, unless the brake is released and depressed. The brake pedal must be pumped like this until the truck is at a complete stop, then the idle is fine and the stall situation is averted. So, what is happening seems to be the engine is attempting to use the transmission to help me slow the vehicle via deceleration. Should I need to corner in this 2 second timeframe, the power steering pump causes added power drain and will stall the engine abruptly and these trucks DON'T turn unless the power assist is available. Is there a
