Redtruck-VA
- Jun 29, 2010
- 5,864
- 984
- Location
- Virginia
- 2003 & 1989 D250 RWD
- Hemi-5.7, 5.9 12v & 24v diesel
The 03 TMR Delete Mod comes up every now and then and only takes a couple of minutes and is free. So I searched around and found pictures from another forum and have posted the mod here for future reference. This mod can only be done on the 03 model, all the newer trucks need to buy a tuner. This is a no BS mod that cost nothing and works by removing the torque management request coming from the TCM to the PCM. I've had this mod installed on my 03 for a few years with no adverse side effects. If you are concerned it will hurt something then don't do it.
Location of TCM...
Remove center bolt and pull plug out.
Remove the red pin holder.
Pull wire from pin #10 and tape off the end. Put it all back together and test drive!
This is really very simple to do, locate the Yellow/Dark Green wire (#10) and remove from the plug or simply cut it leaving enough to reconnect if you ever want to. Fold back the ends and cover with heat shrink.
I don't know how to cut and paste from a PDF file but you can find the schematic on the 03 manual at "Transmission Control System" (8W-31-8).
Good luck....
Location of TCM...
Good luck....
