devon1996
So I've got this 04 hemi and it's got a bizzare issue. Alternator light comes on randomly and when it comes on the temperature gauge stops working. You can turn the truck off and back on and it will go back to normal. I cleaned the block ground and the ecm ground on the firewall with no improvement. I even ran a wire directly from the ecu ground to the block. Battery is charging fine and the truck runs fine but it has a check engine light on for the temperature sensor. Sometimes it pegs to max heat and sometimes it's stuck on cold. Charge meter works fine.
