fosgate3
I started having a problem with my 545RFE transmission on my 2004 Ram 1500 (5.7L Hemi; 337k miles). While driving at lower speeds (<60mph...usually between 25 and 45mph), the truck sometimes has a mild jolt; and then, when I come to a stop and then try to take off, the truck feels like it's in second gear instead of first. I have also noticed when this happens, that the truck will not upshift to 3rd and higher. If I pull over and shut off the engine, and then start it back up, things will "reset" and work fine but eventually it does it again. This morning, it happened at least 3 times while driving through town.
I changed the fluid not long ago when I rebuilt the differential last fall but I went ahead and changed it again, along with both filters. I was surprised at how much fluid came out too---I ended up having to put in around 8 quarts when refilling it in order to get it to where it needed to be when hot. I checked it again this morning after the 3rd instance of this issue and it was still perfectly topped off.
I read something about the shift solenoid pack being a possible culprit but I was also told by my buddy at my local O'Reilly's that it could be the issue. I've worked on engines a lot but I have little experience with diagnosing transmission problems. Can anyone give some suggestions?
Thanks in advance for reading.
