Gerald Sheppard
I have a Ram 1500 Big Horn Edition 4x4 with the 5.7 and 5 speed automatic trans. The truck has just over 94k miles. I recently noticed and odd squeak type noise that seems to be coming from the rear, as I only hear it with the rear slider open. At first I thought it was possibly a dry u joint. The noise only happens while under no load or just when you give it some light throttle. Since the joints can't be serviced, I replaced them with new Spicer units and found them to be in good order. I have noticed that it does not seem to make the noise if I apply light brake pressure, leading me to think it could be brake related. I haven't removed a wheel as yet, was wondering if anyone else has experienced this.
