10.5" Screen - No back up camera
Giorgio_Rampa
Vaudreuil
V6 3.6L
My friend installed this screen in his 2016 RAM 1500 SLT, however the backup camera no longer works (everything else is working fine).
Has anyone encountered this issue? if so, what needs to be done to get the backup camera to work?
Screen:
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
If ever someone installs this screen from Amazon, make sure the seller gives you the code for the factory settings (had to file a dispute with Amazon just to get the code)... once you get it, you can set the camera to "CVBS".
The screen will restart and your OEM rear back up camera will work (make sure it's plugged into the CCDV wire).
