O wow so I'm unlocking my limiter should I consider and different drive shaft also???Yes you ran into the speed limiter, it's to keep the driveshaft from possibly exploding. Someone on this forum blew his up after having the limiter tuned out and attempting to race someone onto the freeway. Factory driveshafts are not balanced good enough for those kinds of rpms
No I dont plan on racing I just want a lil more speed n power n the most performance out of my mostly stock ram...do u think I'll be good?@dell1991 if you plan on racing with your truck. Look up some of the guys on this forum that drag race their trucks, they'll better be able to tell you which truck configurations drive shafts are more susceptible to failure.
I have the 4wd full cab full bed crew...and I also have different tires and wheels on my truck...thank man ur very informative by the way...so what do u think now?The only trucks with driveshaft issues are the regular cab 2 wheel drive shortboxes with the 8 speed transmission,it's really bad with the trucks with 3.92 gears,the trucks with 3.21 aren't quite as bad.If you don't have regular cab 8 speed shortbox truck you're good to go.
Actually the limiter is set for the tires more so then the driveshaft. The trucks come with cheap tires and the tires aren't rated for much more speed then the limiter is set at. I forget what the SRA's are rated for,i'd have to go look,but I think they're speed rating is only around 110 mph. I took them off my truck the second day it came home,and sold them,so I don't even have one to go get the rating off,but if you're interested just google Good Year SRA's speed ratingand you'll find it
The only trucks with driveshaft issues are the regular cab 2 wheel drive shortboxes with the 8 speed transmission,it's really bad with the trucks with 3.92 gears.....
