114000 miles 2018 6 cyl
Ohio5pt7
Ohio
Just turned 114000 miles on my 18 ram no problems. Just maintance. Replaced tires and brakes at 60000. No maintance done on trans. Replaced brake fluid. Mostly highway miles.
Holy hell that is crazy for a 18 lol.
Sent from my SAMSUNG-SM-G891A using Tapatalk
P
papanogo
ft. myers, fl.
6 cyl. gas
116000 today. Called my dealer today and he said don't change it till 150,000 miles. Who the hell do ya believe right.
P
papanogo
ft. myers, fl.
6 cyl. gas
Over 116,000 miles today. Called my dealer today. He said don't touch it until 150,000
$700.00. who the hell do ya believe right???? I'm so confused.
FXCLM5
2017 Laramie CC
ED 3.0 V6
dunno what your confused about, are you seriously trying to shove the $$$ down their throat?
he is literally recommending what i stated, but if you want to keep listening to others on this forum that recommend changing it every 30k go on ahead
Coramie
Lago Vista, Tx
That’s the best thing about the lifetime warranty. Everyone is trying to figure out when to change fluids that the manual says don’t need to be changed. If my transmission craps out, I will have followed Ram’s recommendations by not touching the damn thing and they’ll be responsible for it. If they wanted to get nasty, by changing the transmission fluid myself, at a dealership, or through another mechanic, they could rightfully void my warranty. Screw that! I’ll run it until it won’t run anymore and hope the truck’s value still outweighs the cost of a new tranny when/if that happens.
P
papanogo
ft. myers, fl.
6 cyl. gas
I still have a while before his recommendation was. I'll just keep watching this thread. Definitely not going the 30,000 way. I've had 4 diesel pickups towing campers and boats to all 48 Canada Alaska and Newfoundland. The last one had over 800,000 miles on it. Quite a few drivers have over 1 million miles on them and nobody drained at 30,000. Of course none of them were 8 speed
Aaron2
Phoenix, AZ
2019 1500 Classic
Totally agree. The manual is pretty clear: don't change it.
grizzstang
Calgary, Alberta Canada
FCA calls it lifetime because they don't care what happens to it once your warranty is over.
They would prefer you never change it and your trans takes a dump so you either have to replace it or buy a new truck.
The fact that ZF recommends 100,000 km changes should tell you everything you need to know since they designed it.
Go ahead and follow the FCA owners manual though because we all know they have your best interest at heart.
PoMansRam
East Aurora NY
Another friendly discussion on 8hp70 / 8hp45 "servicing"! :chair:
Like said, given it's only 2yrs old, with a crap ton of highway miles on it with minimal light towing, the ATF is probably fine. Would I still want to swap pans and top back up with fresh ATF? I sure would. If you didn't want to tackle it yourself, I'd have a trusted transmission or general repair shop do it over a dealership once out of warranty like you are.
DA Smith
Marshall Texas
That is specific to the 6 speed. Idk what page it’s on, but somewhere in that section it also says the 8 speed is a lifetime fluid fill and does not call for fluid and filter service unless the transmission is opened up and drained for some reason. I understand being skeptical of lifetime fluid specs, just be prepared the 8 speed isn’t a typical fluid and filter change. The pan and filter are integrated so the whole pan has to be replaced, and the fluid fill procedures are very specific.
That's a fact on the 8 speed, friend of mine is a mechanic at a Dodge dealership and he also said that the fluid is somewhere around eighty dollars per quart . Guess that's why they say lifetime on the eight speed.
DA Smith
Marshall Texas
Maybe things are different in Canada, but my lifetime warranty I received with my new 2019 Ram Laramie actually States unlimited mileage and is in force for as long as I owne the truck. Who knows I may keep the truck for the next 25 years of longer. So to me that means no matter how many miles I put on or how many years I have the truck it is covered.
slacadjuster
5.7L
Wow, 114,000 miles on barely a 2 year old truck....nice job!!
P
papanogo
ft. myers, fl.
6 cyl. gas
NOW GETTING READY TO TURN 160000 AND I'VE BEEN OUT OF WORK FOR 3 MONTHS. CHANGE OIL AT 10% ON GAUGE. GONNA NEED TIRES SOON. MICH. 92000 MILES ON THEM. ROTATE EVERY OIL CHANGE. HAD REAR FLUID CHANGED SAME TIME AS TRANS. ONLY PROBLEM SO FAR IS I HAD TO CHANGE THE WINDSHIELD WIPER MOTOR.
gfh77665
SE TX
2019 Classic
3.6 Pentastar
That is insane. Top of the line ATF's don't cost anywhere close to that. MaxLife is $17.97 per GALLON at WalMart. Even Amzoil ATF is just $10-$17 per quart.
I love the RAM brand and I love my truck, but this is total BS.
Just curious, what would a 8sp. replacement trans costs?
ASouth86
Chesapeake, VA
Damn that is a lot of miles in a short time. I have around 130k on my 2013, and haven't had any problems besides having to replace the thermostat. Will be replacing my coil packs with MDS ones, Spark plugs, and PCV valve when I get back from deployment and having the brake fluid and cooling fluid flushed. I am also debating changing the trans pan/oil, not sure how to tell if I got the regular warranty on my truck or the lifetime. Is there a way I can look this up? I bought my truck brand new in 2013.
Different Drummer
North East
Pentastar V6
Can you tell us what your transmission Temps. have run over the last 160,000 miles?
sanravel
Upstate SC
3.6l
7 quarts of Mopar 8 spd ATF is $123 total on Amazon. I changed my fluid a couple of months ago. It was simple to do and I used a new pan that has a replaceable filter.
