130 lb torque lug nuts.....
brad byron
Longs, S.C.
so, after checking torque on my new/used 2015 Ram 1500 that i picked up(aluminum factory 19 inch wheels) come to realize that torqueing to 130 ft/lbs makes those puppies REAL tght. question is, if ya get a flat on the road somewhere, how do ya get them nuts loose..?? didnt look at the lug wrench that comes with the truck(under the passinger seat) but have to imagine that it's not REAL long to apply leverage to get them loose.....any thoughts.....except spending lots more time in the gym, that is......
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
130 LB's is not much in comparison to bigger trucks. Invest in a 1/2" cordless impact gun and press a button or carry your own breaker bar and socket
BadHemi2014
Greater Cincinnati area
I have a length of pvc I throw in the toolbox just for that. It's about 3ft long makes a hell of a breaker bar. Mostly in case the kid who rotates the tires gets all crazy with the impact.
Also came in handy to break loose the caliper bracket bolts, talk about TIGHT!
buddy guy
alberta
I carry an up to 150lb torque wrench & appropriate socket in my tool tote. Easy!
Sent from my SM-N960W using Tapatalk
Sherman Bird
Houston, Texas
I carry an old Craftsman 18 inch breaker bar with the correct size socket. Math tells me that I only need 2/3 of the torque force to accomplish proper tightening spec..... about 80 pounds. One needn't be built like Charles Atlas to accomplish 80 pounds of force. It is also a wonderful outlet for frustration energy!
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
FWIW 110# on my clicker for 4 years on hub-centric aftermarket dual drilled, it’s plenty for an aluminum wheel and 9/16” stud. Never have had one loosen up even using a little permatex lube.
JeffN
Porsche centerlock wheel nuts require 440 ft-lb of torque, applied with the wheels off the ground. I use a 3/4” breaker bar and torque wrench from Precision Instruments, all 4’ of it.
turkeybird56
Central Texas
I carry a Breaker Bar under the rear seat, along with deep well 6 Point 22 MM socket, which is the size for most stock Ram lug nuts. If I go on a long trip, I take a cut down tool box which also, btw, includes a torque wrench, but I's a BOIRD...
BWL
Embrace the skeptisism
BC Canada
I have a 1/2" impact behind the rear seat. Knocks them right off. I torque to 135 and always re check after I drive a bit and again after mire driving if any were loose on the retorque. I've lost a wheel. Rather it didn't happen again.
Sherman Bird
Houston, Texas
Back in the '80s. Porsche had a 911 model with magnesium lugs nuts. These required an aluminum socket and had anti-seize from the factory and required a fairly low torque. I do not recollect the torque spec. And those cars routinely went over 100 mph!
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I have a 1,000 ft lb torque wrench if you know anything about air planes you’ll know why ;)
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
2009-2011 wheel torque spec 130 ft lb
2012 wheel torque spec 135 ft lb
Apparently between 2012 and 2015 it went back down again. My truck is a 12 that's why I know this
RoadRamblerNJ
Knoxville, TN
392 Hemi
This. Under my back seat with several impact sockets in metric & std.
I also lightly coat lug studs with Never Sieze and yeah, I know they say don't. They also say you can loosten lugs with a short, bent jack handle too but, I won't fall for that ever again. Re-torque them after initial install to ease your mind. Haven't had one come loose in over 45 years.
PS: Let your spare down & hit that with Neverseize too before you need it..4896148e50f8330b7d910a5cf3953547.jpg
BWL
BC Canada
I also have one of those milwaukee monsters. Not for tightening the bolts, but they come off with ease. Also, I believe a 22mm socket on that will raise and lower the scissor jack a lot easier than using the contraption that came with it.
TomB 1269
Schenectady NY
2019 Classic
Personally I think the manufacturers tend to overdo the torque needed for the lugs. I have had a couple of different trucks / cars with high torque specs, but have always used 100 - 110 ft/lbs for my lugs and have never had any issue.
senator49
Choctaw, Oklahoma
I have a 2011 2500 crew cab with 17 inch wheels. They are Black Rhino Sierras and require 135 foot pounds of torque to secure the lugs nuts. I carry a half inch breaker bar and the 21 in impact socket needed to break them loose and to tighten them. If I have to change a tire along the rode, I will recheck the lug nuts torque when I get home with a torque wrench. I also carry a floor jack in my bed tool box to make the whole process faster and easier. The truck is heavy and so are the wheels and tires. All this also makes helping someone else along the rode a whole lot easier.
Elkman
Monterey
V6
With my truck I carry a 1/2" drive 25" long breaker bar along with a deep 22mm socket so I know I can remove the nuts regardless of the air wrench setting used at the tire shop the last time they were rotated. I can provide more than twice as much force with the breaker bar as I can with the factory tool.
For $35 this provides me with what I need and it is always going to work when needed.
bm02tj
B C Canada
The coarse thread needs more torque than the old fine thread
I never let them tighten with air wrench and make sure the nut moves when they tighten with a torque wrench
Then I recheck when I get home
am3334
