14 PW Diff fluid change procedure
rogueknightatx
6.4L
I was wondering if someone can walk me through the procedure to change the diff fluid on my Power Wagon. I understand that it's just a remove of the cover and refill to the proper fluid level, but with all these crossmembers in front of the the covers, what tools do I need to access these bolts best? I I quickly realized that the tools I have on hand are not sufficient to reach those bolts have very low clearance to some of these cross members and also I don't have sockets deep enough for some of these either.
Phil21502
Frostburg, MD
Easiest is to just take the sway bar off from the axle. Then ur clear to remove the cover
loveracing1988
Clarkston, MI
Just a deep well 13mm to take off the cover pan bolts and if needed for clearance I think the sway bar bolts are 15mm that holt it to the axle.
Sent from my LG-H918 using Tapatalk
PatinAZ
My '16 PW does not have drain plugs.
I did my front/rear at 20k miles. Nothing to it. Just look and see how any brackets attach that might be on one or two of he bolts. The gaskets are reusable. I cleaned some crud off the magnets with some q-tips and nothing else. Diff lock seems a little easier after.
reloaderguy
Oregon
2016 Power Wagon
The diff cover will come off without removing the sway bar.
reloaderguy
Oregon
2016 Power Wagon
It's been a while but just lift the cover up after all the bolts are out. I don't recall it being difficult.
R
rogueknightatx
6.4L
Ended up removing the sway bar like folks suggested. After that it was was a breeze.
Sent from my ONEPLUS A5000 using Tapatalk
