14 ram 8hp70 used transmission
MoparManiac440
Hull iowa
Hey, I'm changing the transmission(8hp70) in my 14 ram due to a slight torque converter slip in all gears. My question is do I have to put that tcm in the new used Transmission or can I just have a dealer program the other Trans to the vehicle without swapping anything.
crazykid1994
You are changing the transmission due to TC slip? If it’s the torque converter wouldn’t it be easy enough to just have that swapped?
M
MoparManiac440
Hull iowa
I'm not sure if it's the torque converter catching the transmission slipping or the torque converter itself slipping, so I found a good used one with 47k on it compared to my 150k trans
M
MoparManiac440
Hull iowa
Had a guy on here claim there was a reflash that addresses this possible slip in a service bulletin but the dealer said that everything was up to date and that they didn't have to do the flash, TC mv were jumping right at the slip, they thought it was TC or trans
