14 sport leveling question
14stormtrooper
Hey everyone just joined so this is my first post. I have a 2014 ram sport 1500 crew cab was wondering if any one can help me out i want to run the bilstien shocks at 2.8 up front with mevotech upper control arms. Anyone have any good or bad things to say about that setup? Also will it fit 20x10s on 35x12.5. Thanks for the help
Hemi395
Cape Cod MA
Welcome to the forum!
A lot of people run the Bils and the Mevotech control arms and they are a great combo. However there's been some people who have vibration while in 4wd with that setup due to te CV joint angle. Most people have alleviated that problem by dropping the Bils down to 2.1". Just something to keep in mind. A lot of people do run the Bils at 2.8". That's the beauty of them, you can adjust the height.
As for the tires, I'm not sure but someone else might know.
14stormtrooper
Okay thanks is there any other ways? I want to do the best route for my truck dont want parts breaking and stuff, i dont plan on offroading it thats why i was thinking of setting it at 2.8
tripower
I'd go with Bills at 2.8" and forget about the Mevotechs. The stock UCAs work fine with the Bills, there are lots of us running that set up. At 2.8" the trucks also look better with a small spacer in the rear - something else to consider.
20x10 wheels? Need the matching 6" lift for that set up :naughty:
J Rod
Ft. Wayne, IN
I was just about to ask that question myself. Don't mean to hijack your thread OP but I think we're both looking for similar answers so hopefully I'm not imposing. I am putting on some Rancho QL's which I'm assuming will raise it up to about the same level as the the OP's Bils at 2.1. I plan to do either a 3" BL or a 4" SL at some point in the future so I was hoping to do wheel/tires that would work for both setups. I had my heart set on 20x10's w/ 35x12.50 tires, are you saying that's not possible with just a 2" level? If not, what is the biggest tire I can run safely?
14stormtrooper
Okay thanks guy im thinking of stay with the stock rim i heard you can fit 35x12.5 without spacers with a leveling kit. I heard atturo trail hawks mt. Any help?
CherryRedRam
Yes it will fit 20x10 rims. I ran 35x12.5r20 trail grapplers with fuel 20x10 -24 offset rims off just bilsteins at 2.8.
14stormtrooper
Okay thanks i think im going to keep stock rims and run nitto trail grapplers
tripower
Not sure about that tire. But when you're trying to fit a '35' on the stock wheel without spacers, it all comes down to the brand and tread you pick. A true '35' that's 12.5" wide will never fit, but some brands undersize their tires. Seems like it's usually the cheaper brands.
14stormtrooper
Okay thanks ive heard 275/65r20s nitto trail grapplers mt r a good tire to run on stock rims
xrsman
Ontario
3.0 Ecodiesel
Some have put 35's on and didn't require a spacer, but mine needed a spacer to fit on. Plus they still rub
I have a level and 3" body lift on 35's. I've got the stock 20's (9" wheels +20 offset) and 1.5" wheels adaptors (make the offset -12).
I rub with this set up. Had to trim up the factory flares but I still hit the mud flaps and wheel well liner.
Sent from my SM-G920W8 using Tapatalk
14stormtrooper
Truck looks good tho really like it
