Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
16 Ram 1500 build
Discussion in 'Member Trucks' started by revitupmoto33, Mar 13, 2018.
  1. crazykid1994
    crazykid1994 Senior Member
    1,967
    881
    Sep 21, 2013
    Ram Year:
    Engine:
    Did you do anything to protect your fuel tank?
  2. revitupmoto33
    revitupmoto33 Senior Member
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
  3. revitupmoto33
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
    I have not.
    crazykid1994 likes this.
  4. crazykid1994
    1,967
    881
    Sep 21, 2013
    Ram Year:
    Engine:
    I’m looking at building something to at least prevent punctures. I’ve got a couple scrapes on the bottom already and don’t need to buy a new tank. Would give me a reason to buy the 32 gallon but... looks like I can go to the mounting strap holes with some angle iron and then put a couple of rivnuts in existing frame holes and should be good with some 3/16” plating underneath
    revitupmoto33 likes this.
  5. revitupmoto33
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
    Sounds like a viable option. I think 3/16 Alum would be more than adequate.
  6. revitupmoto33
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
    Had quite a bit of scrap metal piled up so decided to build a hitch mounted swing out tire rack instead of my normal style ones. Figured it would be less welding a cutting.
    Still need to add the toggle clamp to keep it snug when closed and maybe one of those spring loaded T pins to help keep it open. May need to throw those 1” spacers back on in the rear depending how much it sags.
    ram1500rsm and 22hemi13 like this.
  7. revitupmoto33
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
    Toggle clamp and poly liner
    ram1500rsm likes this.
  8. hodge-xj
    hodge-xj Senior Member
    1,922
    1,442
    Jun 7, 2013
    Ram Year:
    2006
    Engine:
    5.9 cummins
    Replying here instead of the everyday thread. I like your design. Mine on the jeep uses the exact same latch, yes it's a bit cheesy feeling but at 10 years old it holds fine still. I did weld it into place, backed into a tree and broke the bolts, but what can you expect. Where did you source that HDPE? I need that!
    All the designs I've seen are alright, but especially for you and your high clearance setup, are way too low. How tight is the fit into your receiver? I do know that's a big issue with most designs, they get some slop, add the leverage of a 35 and you're looking at a headache in short order.
    Me likey. Need to get back to just 1 vehicle, the ram is being neglected
    Sent from my SM-N920V using Tapatalk
  9. revitupmoto33
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
    I debated whether or not to weld it in place like the first swing out but did the extra effort drilled/tapped for the clamp. I got the uhmw off amazon, came in 12x12”, using the rest as a camping cutting board.
    So I actually did a receiver mod a few years back when I had my linear actuated lifting dirt bike hitch hauler setup (I got all sorts of fancy with that one). I’ll take a picture a little later of what I did. It takes every bit of slop out of it. Just drill a hole through one side of the receiver and weld a 1/2” grade 8 nut to the outside and use a bolt to put tension on it, same concept as a jacking bolt.
    https://www.amazon.com/gp/aw/d/B000ILLNJ8?psc=1&ref=ppx_pop_mob_b_asin_title
  10. revitupmoto33
    635
    1,135
    Mar 11, 2018
    Orange County
    Ram Year:
    Engine:
    3.6
    hodge-xj likes this.
Share This Page
