Nickmigues12
Hi all, back again with another issue on my RAM (still haven’t resolved my 3 way valve issue but that’s for another day at this point lol. As stated in the title it’s a 16 with the 3.6, and I have 198k on it. I have an oil leak, and having a hard time pinning it down- I fear it’s the rear main seal. I know what you’re all thinking- oil filter housing- but it’s been replaced with an aluminum one a few years back, the back of the block is dry and one of the other tell tale signs I’ve noticed in the past (I’ve fixed this leak more than once in the past on my truck and other trucks) is that typically the trans lines that run under the bell housing are typically wet as well as the transmission pan, which is all dry. Also had new valve cover gaskets put in earlier this year when I was replacing some rocker arms. Only place that has any oil is where the trans meets the engine, the dust plugs and of course it’s all over the oil pan and block in that area. So I’m curious what anyone else’s experience is- anyone ever actually had a rear main go bad on these? Or do they have one of those stupid upper oil pans that could be leaking in the back? Could the actual oil pan be leaking and somehow throwing oil upwards? Going to do some deeper investigation tomorrow or later this week when I have time, this was just a quick observation I made today but always love to get ideas from knowledgeable people on forums! Thanks.
