18" vs 20" wheels
Glenn54
Glenn54
Deep East Texas
Those tires and wheels look awesome! The 20" wheels I don't care for are the ones with low profile tires.
Hey i'm another old guy and I love the look and ride of 20x10 rims mounted on 37s, for some reason the visual balance is just right to me, they also looked really hot on my 33s before I changed up. the tires are 12.5 wide. As I said almost everybody loves the look. Good luck with your choice.View attachment 169215
Elkman
Monterey
V6
The larger the rim the shorter the sidewall is going to be with any given tire diameter and that translates into a harder ride and a greater chance of popping the bead of the tire. Adding more mass with the larger tires also translates into a harsher ride with the shocks having to work a lot harder and probably why the Rebel is available only with 275/65R18 BSW All-Season LRR tires on 18 inch rims.
19Jake
♕ REBEL LIFE ♕
SICAMOUS
'19 Rebel 12 HK
OEM 275/70 Duratrac 33.2"
18x9" PRO COMP Series 46 PRODIGY Øffset Satin Black
2½" wider track - Mopar flaps/boards
REBEL 12 Redeye 3D center cap inserts - open end black lugs
hookers_n_blow
Pennsylvania
I agree. The balance of this looks just right to me. How much lift is that?
Bennyrok
Tewksbury mass.
5.7L HEMI
4 inch Superlift for my ram, thought it was just right seeing i'll be 60 next year and want to still be able to still climb in and out, Hee Hee>>>> :)
2016 Dodge Ram 1500
Mine came with base wheels on my Laramie and I’ve since switched several times. This is my current set with Toyo AT / II in 275/70 fitment. My last set were Toyo in LT 295/70 and what I have in my garage are brand new 275/65/18 Cooper tires.
Thanks for sharing. Definitely want more meat on the tires for sure... So going to be shopping for 18" wheels, might be a little bit more comfortable than 20s. What size are you running on your 18s?
DRkNESS
South Jersey
I currently have (2) sets of wheels. The 18” set have 275/70 on them and the 20” set have 275/55 on them.7c5c7aa49cbe8753029f158c79a82b78.jpg
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
So is there really an issue with some aftermarket 18” wheels clearing our brakes? I’ve always liked the 20’s but it has crossed my mind a time or two about dropping to 18’s.
I figured it was 17’s we had to avoid....
DRkNESS
South Jersey
There really are as some wheels depending on style and offset will cause problems. I took(2) trips totaling 1100 miles each with both sets of tires and the ride quality was the same in my opinion. I can’t see how 17” wheels would fit unless they were custom made.
JoeCo
NY
I believe this isn't a problem on the 4th gens, just the new 5th gens.
buddy guy
alberta
i read today too that the UCA's on the 5th gen have plastic inserts on them to save weight and cost making the UCA's less durable in 5th gen than 4th. (on the topic of differences between the 2) that came from the Ram 5th gen forum.
