180 T-stat
StoneDude76
West Chester,PA
Ok I've tried searching using Tapatalk but came up empty. I want to delete my clutch fan and drop a 180 T-stat in. I've seen somewhere that Autozone stocks these. Does anyone know which one I ask for? And what type of antifreeze does my truck use? I have a 2014 Ram Hemi.
Sent from my XT1080 using Tapatalk
Paluby
Alaska
It's just standard mixed coolant from autozone. You can look on the container to see how cold it's good up to.
If they have a 180° Tstat for your truck there then I don't see the issue. They will ask you for all the info to match it to your vehicle before selling it to you.
bassheadhemi
Montreal, Canada
no! don't put "regular" coolant in a 2013+ or you will damage your cooling system.
Unless you do a complete flush, the only coolant you can use to top off is the one from the dealer specific for 2013+. I think there's some compatible ones starting to show on the market, but better safe than sorry.
Chris. lerma
Indianapolis, Indiana
Taken from my PDF version of my 2014 Manual.
5.7L Engine – 1500 Models (We recommend you use MOPAR®
Antifreeze/Coolant 10 Year/150,000 Mile Formula that meets the
requirements of Chrysler Material Standard MS-12106.)
16 Quarts 15 Liters
Paluby
Alaska
Huh. The service manager at the dealership here told me that it didn't really matter. My bad.
Pull Ya
Cedar Creek, Tx
The anti-freeze must be HOAT compatibly unless someone has already done a complete flush and used something other that what came in your truck.
Jay
bassheadhemi
Montreal, Canada
Jay
No HOAT is what was used in pre-2013 model. From 2013+ they use a special blend of OAT and can't be mixed with anything but water
Pull Ya
Cedar Creek, Tx
Sorry, your right. I was looking up 2012 for some reason. Must need another cup of coffee
Jay
Jmhm17
Massachusetts
5.7L HEMI
Just get a gallon of premix at the dealer, ask for the "purple stuff" You will not lose more than a galon. I have the AZ t-stat. Its in my shed, ill grab the part number in a few. I think it was 12 bucks or so
Jmhm17
Massachusetts
5.7L HEMI
NOTE! Do not get rid of the gasket on the factory T-Stat, the AZ one does not come with one. So, if you rip it or it was messed up when they installed it your going to have to get a tstat from the dealer as I dont think they sell just the gasket - so just be mindful
Paluby
Alaska
Just did some research considering the route this thread went and the opposite information my service mgr friend at the local dealership gave me.
Found this information on another forum posted by another professional.
"If a customer chooses a different type of coolant than that which was originally in the vehicle's cooling system, the cooling system should be flushed to remove all of the old coolant. This will avoid any potential incompatibility issues between IAT, OAT and HOAT coolants. We have not heard of any horror stories of bad things happening inside a cooling system when different types of coolants are intermixed. But antifreeze suppliers caution against mixing different types. Their advice is to use "same with same.""
Part number for a 180 "Stant" thermostat is # 48798.
You'll have to ask for a thermostat for a 09 Hemi,as nobody lists a 180 for the newer trucks,they're the same thermostat,but nobody lists it as fitting anything newer then 09.
Paluby
Alaska
Or just go to Moe's performance. They sell 180° for newer trucks.
Jmhm17
Massachusetts
5.7L HEMI
You're welcome for posting pics..... Literally just look at my post and order that stuff and you're done /thread..
StoneDude76
StoneDude76
West Chester,PA
I just got the Duralast 4127. They didn't have the 4128. Will I get any DTC from getting the 170? Anybody have issues with this thermostat.
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
Anyone else noticed that when they changed their TStat that the coolant kinda smells like soy sauce? Also there was some snot looking sludge on the stock tstat. I only have 1200mi on mine and was surprised to see the snot. Thoughts?
