19 2500 BDS Lift towing question
rh1077
Miami, FL
Cummins
Hello,
I recently installed a 4" BDS lift on my 2019 2500 rear coils. I'm going on a trip soon and will be pulling my boat which is probably weights 12k - 13k +/- when loaded I'm thinking. It sits on a triple axle trailer. Before anyone asks, the boat sits in a marina in the water so it is not currently on the trailer.
I pulled it a couple of times when the truck was stock and it did a great job.
So my question, am I going to get a lot of rear squat with the lift?
I've been considering getting a set of air bags for this. Is this necessary? Does anyone have experience with this?
Thank you.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Hello,
Thank you.
Is it a standard hitch or gooseneck trailer?
Is your truck gas or diesel?
Bds uses progressive rate springs adding airbags is never a bad idea when towing but you will need custom brackets fabricated to accommodate the lift
R
rh1077
Miami, FL
Cummins
Standard hitch and diesel
