'19 Rebel: Aftermarket wheels without lift or leveling kit
Theo2019
California
Hey guys, looking for a decent aftermarket wheel that will fit the LT275/70R18 without a leveling kit or a bigger lift.
Can't seem to find an 18x8 with a 6x139 and -12mm (or other negative). Will an 18x9 fit these tires?
I've been looking at method and fuel 18x9 wheels. Thanks!
McBroom
Denison Tx
Hemi 6.4L
Yes they will fit. Be sure to measure the back space on the 18x9’s if they’re to deep they might rub the suspension. I recommend a-12/-18 wheel.
Look at RBP wheels. That’s what I put on my 2500
Theo2019
Theo2019
California
Those wheels are high quality for sure! I'll have to check out RBP wheels. What are the specs on your Nittos?
Thank you, McBroom!
McBroom
Denison Tx
Hemi 6.4L
Thank you, McBroom!
35x12.5/20” I’m going with a 37x12.5-20 M/T on the next set of Nitto’s. Next Christmas
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Off Road.
olyelr
Kewadin MI
So, -12/-18 offset if I wanna keep it 18?
There is no way in hell I would go with a negative offset wheel like that, especially with a truck on stock suspension. That will just look goofy as hell in my opinion.
McBroom
Denison Tx
Hemi 6.4L
No not necessarily. The neg offset just moves the wheel further out of the wheel well to widen the stance a bit. A neg 12 offset is almost 1/2” a neg 18 is a tad over 3/4”.
Think old school... deep dish wheels or even the reverse wheel. It’s the exact theory.
All factory wheels are a positive offset +**
Look at some of the pics on @customwheeloffsets they’re a preferred vendor here
The Blue Mule
R
Rogues Gambit
Guest
Gotcha gotcha, just trying to figure out for clearance and stuff
Thanks btw guys, now to check it out
blackbeautyhemi
Lewistown, PA
-12 offset really isn’t much of a offset tho
bigdave2212
4.7L
I put -24 on my truck. I did the links n stuffed 35"x20 rim under there but I don't think it looks bad. I love the stance now! 20190203_135508.jpg
Sent from my SM-G975U using Tapatalk
silverWS6
EPTX
Damn, that looks legit! Any rubbing on full lock? Or flexing?
19Jake
♕ REBEL LIFE ♕
SICAMOUS
'19 Rebel 12 HK
perfect fit w/Mopar splash guards & OEM Duratracs
custom Ram Redeye center cap inserts
2.5" wider stance than stock
bigdave2212
4.7L
Yes there is a slight rub but only on the 2 fire wall pinchwelds. The stock flares were rubbing also so I replaced them. I could take n cut the pinch weld but I've been lazy about it. It's not too bad! But I love the truck now! Still getting compliments on the color! 896939346901d6a0bf50e1797befa9e1.jpg6b803f0737e3dded29f403df8eb00f35.jpg4f7117ba4a45467b642d976723af9c37.jpg
