Huttemannc
Hey, I have an 89 with a 318 that has about 53k original. Never rebuilt. About a month ago it started running super rough. It idles fine, but under load it just has no power and bucks and shakes real bad. I was thinking spark, so I changed the plug wires, plugs, cap, rotor. Solved nothing. I was thinking fuel delivery, swapped out the fuel filter, fuel pump, fuel lines. Solved nothing. Both injectors on the tbi seem to be pushing the same volume, should I swap them? I know i need to replace the temp sensor, as it no longer reads on the dash, that wouldn't be the issue would it? it went out months prior to the engine running rough. Throttle position sensor? Vacuum leak? Ive looked for leaks and cant find any, it seems to idle at a constant RPM. Jump time? That is something i really havent looked at, i dont have access to a timing light, but can get one if need. What is the recomended advance on that engine? What have you all found to be a time setting that is good for a daily driver? i really am at a loss here. Is there any benefit to puling the TBI and dropping a carb on it? what all is entailed in such a task? any carb suggestions if that is the route to go? Dash codes are normal with nothing hinting at the engine, just a battery negative disconnect (?) and a A/C relay fault. Any help or ideas would be super helpful. Thanks.
