ray hall
- Jan 28, 2014
- 35
- 2
- 1983
- 225 slant six
Ok so my 89 360 is doing some strange things. I had a code 13 which I posted about a few weeks ago but nobody responded. I put a spare map sensor on it I had and the code stopped showing up but now when it's cold or its sat a little bit after it been ran and you start it up it will normal for a few seconds then starts backfiring off and on. Smells like it's running rich then it will start shuddering out and missing almost die then tev way up and smooth out then repeat. It will do this about 5 or 10 minutes then it will smooth out and run perfect until it cools down then it will do it again. Since that started after I changed the map sensor I figured I had 2 bad map sensors so bbn I just bought a new one and put it on still the same issue. I currently have no codes and I'm not sure where to go with this. Injectors look to be spraying fine. Has about a year old fuel pump. New egr valve last year. What gives? Once its warmed up its fine
