NealC
I have a new 2012 R/T. The book says the first oil change is required at 8000 miles. In general, I will change the oil at 5000 miles intervals but I was wondering if the first oil change should be done sooner, like 1000 miles? Is the oil in the engine a "break in oil" that needs to be changed sooner or is just vanilla 5W20?
Oil filter question, I usually use the K&N high performance filters with the 1" nut on the end to make them easy to get on and off. Is it OK to use this filter or is there something special about an OEM Mopar filter?
