Alphaogre
- Jul 30, 2018
- 3
- 1
- Location
- San Diego CA
- 2005 2500 SLT
- 5.9 Cummins
Hello All,
I picked up a 2005 2500 Cummins with 167,000 miles in a 4 door long bed 2WD. It came with the full Banks set up intake through to exhaust, whether it helps or not.
I traded up from a 06 Tundra, and I have only had light-duty trucks so far. I don't do any super heavy towing right now. The most I currently would have loaded on it is an older pop-up camper and towing a car or a couple motorcycles behind it. I bought it with the idea to overbuy and underuse...hoping I can get some more longevity out of the vehicle over a longer time. My Tundra was getting close to 200k miles and I could tell the strain was starting to wear on the poor little truck.
Anyway, Not trusting the service records, I like to set a baseline for everything myself. I just had the belt changed (since you could hear it squeak while running), we did all new oil and filters obviously, and then I had them do the tranny fluid and filter, and swap all the diff fluid.
I Have squeaking on the front end. I've been told it could be the upper and lower ball joints (which are apparently pressed in on my year) This has been quoted at between $600 and $700 which sounds about right given the cost of the ball joints themselves for heavy-duty load. Then they mentioned that if its the bushings at the arm mounts, you might as well get all new upper and lower arms, and it would be $2000. This seems drastic to me...has anyone else gone through this process? Any pointers would be welcome.
I've been trying to get more information as to what to keep an eye out for moving forward. It's been hard to get specific info for 2500 in 2WD configuration. Any thinks to keep in mind would be great as well!
Thanks!
Chris
Thanks!
Chris
