Tim7139
- Oct 24, 2015
- 729
- 302
- Location
- Alberta, Canada
- 2020 Classic ST Crew 4x4
- 5.7 Hemi w/8 speed 3.92 gears
I really am quite confused on exactly how to operate the vehicle correctly according to manufacturer suggestions.
Then focus on the only on the manufacturers guidance.
Some examples:
The Diesel Supplement tells you to warm up before applying a load. You have no load to apply, so no action required. No need to ever think of it again. Step 6 of the STARTING PROCEDURE — ENGINE MANIFOLD AIR TEMPERATURE 0°F TO 66°F (–18°C TO 19°C) is DRIVE. Not warm up, not override idle DRIVE.
The manual tells you to idle for less than a minute empty with a cool turbo. It also lets you know Towing/hauling max weights in the mountains is the only time to anticipate a hot turbo, which you will not do, so no need to ever think of it again. Let it run for a few seconds to a minute and you will be following manufacturers guidance.
