2.5" receiver to 2" sleeve causing RATTLING and MOVEMENT on bike rack
Bryan tahoe
Tahoe
6.7 cummins
My Ram came with a sleeve that sizes down the 2.5" receiver to 2". I just got a 2" bike rack. But the adapter sleeve is loose and causes the bike rack to move all over the place. Does anyone know of a shim or locking kit that could keep everything motionless? Thank you.
jawzs2
South Jersey
Dean2
Near Edmonton
If you are going to leave it in permanent have it tac welded in place. If you want to be able to remove it you can drill and tap a screw through the side of the 2.5" receiver to tension the sleeve. Other choice is to wrap the sleeve with nylon, or hockey tape before sliding it in place.
B
Bryan tahoe
Tahoe
6.7 cummins
I think I found a solution, I'll post later.
mtofell
First thing I'd try is just a different brand. Mine fits nice and snug.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
You could get someone with a welder to run some beads about 6 " long on the part of the adaptor that fits inside the receiver, or maybe the welder or you can figure out a better way to build up the adaptor shaft.
If the bead is a bit thick, just use a grinder to take a hair off.
The welder would not have to be certified, just someone that knows how much heat to use
John Jensen
San Diego County
Ecodiesel
Have the adapter tack welded to the receiver, That would remove any play and still be able to cut or grind off the tack welds if necessary in the future
2003F350
6.7 CTD
Put the bikes in the bed.
Yeah I know it's a smart-ass answer...but unless you've got an astronomical number of bikes you should be able to make them fit. When I was a teenager we used to fit 4 adult-size bikes (dad, mom, me, my older sister) and 2 kid size bikes (my younger brother and sister) in the back of my dad's truck whenever we went on vacation.
jvbuttex
I-6
my bike rack has a bolt used as the pin. so there is a nut inside the rack that when in place the bolt tightens it all up. yes the slop is a PIA. If you really wanted, you could look around amazon / google for the bolt insert, there is a clip that holds it in place you could add to yours.
jvbuttex
I-6
yup the Curt anti rattle clip is exactly what i have in the rack. Thanks for posting a pic, worth more than 1000 of my words.
JayLeonard
6.7 L Cummins
I added adhesive backed stainless shim stoct to 2 sides of my adapter. It is a "tap" fit now and doesn't rattle at all. I also shimmed my Equalizer shank the sae way and it rattles a little bit but not bad.
jvbuttex
I-6
@JayLeonard yes i have the similar issue with my WDH on the trailer... its a b@#$% aligning that reducer and the shank itself. Almost ready to pony up the $$$ for the bigger shank.
2003F350
6.7 CTD
If your reducer sleeve didn't come with a flange on the outer edge to keep it from sliding in too far, I'd buy a different sleeve - you likely don't have the factory sleeve anyway. Mine came with a flange on it and the holes line up almost perfectly each time, I've never had an issue, whether it be with my WDH, a standard hitch, my B&W stow & go...
JayLeonard
6.7 L Cummins
I have the factory reducer with the flange. it lines up fine.
jvbuttex
I-6
yes my aftermarket does have little nubs on the end of the reducer, not quite perfect alignment, I manage.
