2 HIDs to 4 HIDs
snidly
MARTINEZ , CA
I have Spyder headlights with halos I want to install in my 07 but I want to run HIDs and not the regular H4's that came with them. The problem is the new headlights have 2 hi and 2 low beams and stock ones use same bulb for highs and lows, basically trying to go from 2 headlights to 4 headlights. I know how to wire the first set of HIDs but not sure how to wire the second set.
Any help would be very much appreciated. Thank You.
derekp
Buda, Tx
1990 5.9 Cummins
So I basically tapped my low beam hids into my park lights with a cheater. I don't have just park lights anymore but I can turn my high beams on at the same time as my low beams, which I love. There are three wires going to the park lights on each side. Use a multimeter to find which park light wire is at 12v with the park light switch turned on. The other wire will flash 12v with the blinker on. Hope that helps and makes any sense.
