2 vehicles, 1 tuner?
AV8B6015
6.7 CTD
I just bought the Trinity for my 2011, but it had to go to the dealer the other day, and after I returned everything to stock, I was eyeballing my other car. Since the Trinity is the same for many vehicles, could I tune the other car while my truck is at the dealer? If so, is there a certain number of times I can do this, or could I switch back and forth between the two constantly?
badblackram06
MS
You can only tune one at a time but can tune and untune as much as you like.
quietpeen
2021 TRX
Hellcat
yes, once the tuner is set back to stock you can put it on the car. Then you can set it back to stock to put it back on the truck.
you just can't tune both of them at the same time
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
What is your other car? As long as it is supported by Diablo, then you can use it on the other car after you have removed the tune from your truck.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
wonder if they make a tuner for a 2012 Town & Country.........get the wife hooked on some SPEED. LOL
AV8B6015
AV8B6015
6.7 CTD
Looks like it's not supported..... 2011 Crown Vic
Stangshcky12
Oshkosh, WI
5.9 Cummins
Some companies (like SCT) do have a limit to how many times you can switch
I don't believe diablo does
MADDOG
Living in a Firepit
6.4L HEMI
In a mini-van? LOLOLOL
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
**** yeah man! :D
2nazt
VA
2012 1500 Big Horn
most tuners that I had you can switch as many times as long as you as you go back to stock as stated earlier, it is when you don't go back to stock and do an unlock you usually only have 5 of those in most cases
Stangshcky12
Oshkosh, WI
5.9 Cummins
From my experiences, bullydog and H&S don't set a limit but both SCT tuners I've used only allows you to switch 10 times
