Milrite
My 2001 Ram 1500 has a 5.2l and is an automatic. Replaced the fuel pump, coil, cap & rotor, alternator, crank sensor, cam sensor, and purchased a re-man PCM and still have same issue; Crank, no start and fuel injection pulse is not there. Can anyone help with this issue. I have done countless tests of wiring, sensor tests, etc. to no avail. I was driving home one evening and all of the sudden it just died. Changed the CKMP after testing the original, which tested bad and tried to start and got RPM for a brief second, then back to the same issue. Tested new CKMP and it tested bad. Now I am at odds as to where to go next. Can't find any info on resistance at the CKMP connector on the harness side. Tested with battery disconnected and had high values. The truck will fire up and get around 1000 RPM with starting fluid and die right out. No fuel to the cylinder. RPM gauge registers when cranking. Re-man PCM was installed and gave a P0753 code, which led down a rabbit hole to nothing. re-installed original re-man PCM and no codes. All relays work and test fine. Where to next?
