I didn't really check for voltage on charging system. opps. This was taken to a dodge dealership service center ( why price so freaking high ) They said alternator was output almost 18v. But when they unplugged the alternator and started the truck they said truck would run only when a code scanner was hooked up to odb2 port, but truck would eventually die. I even told them watch the cable for code scanner it will get really hot and melt. Yeah, i thought price was way to high, so i told them nope and had it towed back home. So far waiting for a rebuild kit for alternator and gonna go from there. Still checking on weather i need another ecm or not. They charged me almost $400 for diag and still didn't tell me, had to read it on paperwork, that after replacing those parts, would still be check for maybe other problems. What kind of diag is that, suppose to find all problems for that freaking high of a price, when i bet they didn't do 2 hours on diag and still charged me 2 hours. I think maybe which i have looked that all the starting problems i may have repaired and the ground somewhere is something new, esp. sense i like an idiot went to pull starter and check dust plate on tranny for the noise i was hearing. I forgot to pull neg cable off battery and you should have seen al the smoke from the grounds i had to replace melting. But still i searched everywhere for ground wires and replaced all that i saw bad or melted. Probably missed one somewhere. ( also on ecm repair and i wrote the people that repaired it, why did you cut a circle over eeprom chip to repair cold solder they said they found. They glued it back on, the metal they cut for easy servicing. I heard that cutting that hole made the heatsink on main casing not good. Never got a response. ) Thanks all
