2002 Gen 2 Ram 2500 Turbochargers
motovate
Northern Arizona
2002 Ram 2500 8'bed
Diesel
I looked but I could not see anywhere to do a search. So here goes - It's probably just another Turbo Question!
I'm pretty sure there is a difference between stock turbochargers on Automatic and Manual engines. I think the manual is larger???? What are the different spec's between Automatic and Manual shift Turbos? I have an Automatic. I'm not looking to go and spend a bunch of cash but I would like the Turbo to spool up quicker. I believe the Manual Turbo will just bolt on replacing the Auto Turbo using the existing intake manifold - is this correct?? Is there a bolt on - no fab or extras required other then stock turbo that will fit that purpose in the $400-$500 range???
Any info appreciated.
LBM
Nealuss
5.2L 318
Someone may chime in, but you're more likely to get the answers you are looking for on a Cummins specific forum. Most of the active users here have gassers.
EddieR
Oklahoma, USA
5.9 Cummins, 6.7 Cummins
I think the HY35 is for auto, and HX35 is for manual. The HY35 apparently has a smaller exhaust housing.
