2002 Ram 1500 instrument cluster problem
Burnley Miller
My 2002 Ram 1500, 5.9 has about118.000miles on . 6 months ago started to have battery issues. 3 months ago started to have overdrive shifting problems. Replaced the overdrive soleiods, governor and sensor. The shift problem continued.
Afew days later the instrument cluster went dead and the red light appeared. No power door locks, no alarm system, now overhead read display or dome light. Engine starts and runs, none of the gauges read and the lights turn on only with the engine running. Ground appears to be good. Scanner said problem is in the cluster. To cluster to repair facility, said cluster was fried.
