2003 1500 backup alarm
art_vandelay
Pennsylvania
does anyone know how i might go about disabling a backup alarm that beeps when i put the truck in reverse? i bought the truck about a month ago and didnt really mind it, but i got a backup camera installed so i dont think the alarm is necessary. i just dont know where on the truck it would be installed.
LugsLeadOut84
NYC Suburb
Do you mean an alert from the backup camera as you are approaching an object? Or a "beep-beep-beep" like a heavy truck backing up? (I never knew RAMs had that)
Are you an importer only? No exporting?
LugsLeadOut84
NYC Suburb
Sorry...It was a reference to Art Vandelay....
What year/model truck? I never knew that was an option but I would think you can disable it somewhere in the menu.
A
art_vandelay
Pennsylvania
haha i am very disappointed in myself for not picking up on that reference.
well it is a 2003 so it is an aftermarket piece.
HemiLonestar
MD
Not a factory option. Can you tell where it's coming from? Does it sound like it's under the truck or maybe coming from one of the taillights?
HandyCruiser
Arkansas
5.7 Hemi (no e-Torque)
It's normally wired directly from one of the backup lights in the tail light assemblies. As noted, you can push the parking brake so the truck will not roll, scotch the wheels in case the parking brake isn't set right, turn the key to the "On" position without starting, put the gear selector in reverse, and the backup alarm should sound. Then follow the sound to the alarm.
At that point, if me, I would put the truck back in park, turn off the key and then follow the wires from the alarm back to the tail light. Then I would cut them there and seal the splices on the tail light wiring with electrical tape. Or better, I would use liquid electrical tape to keep water out. Once the wiring is unattached, I'd remove the alarm.
Badger 13
North Idaho
2013 Dodge Ram 1500
I'm sure this is mounted somewhere near, and under the back of the truck. There is usually two wires that go to them, so just remove one of the wires. If you want to keep it and use at times, just put in a simple SPST switch inline on one of the wires. It should be easy to find, turn the ignition on, set the e-brake, and place the truck in reverse.
Daw14
They may have jumped power from the trailer light wires , I’ve seen ones that plug into light socket.
