KnightHawk1971
- Jul 17, 2018
- 6
- 3
- Location
- Peoria, Illinois
- 1998
- Magnum 5.2
My friend bought this 2004 Dodge Ram 2500 4 door. It had a head gasket leaking water into oil. Had someone work on it. Lifter is still tapping. Was idling about 300 to 400 rpm and a little hesitant on take off, Not too hesitant. We started using it for pull truck cause he junks old cars. Today at Junkyard while I was in office collecting money I came out and the truck wasn't running anymore. I tried to start it. It would fire here and there but not start. Friend showed up and got it to start finally. Have to push gas peddle down a little to get it to start. Wouldn't idle anymore. Misfiring here and there. We got back to shop and unhooked trailer.
I brought truck home and changed all 16 plugs. It idles about 150 to 200 with breather off. Won't idle while on. Seems like its running even worse now. My ELM 327 adapter and Torque pro got two codes. P0157 Powertrain O2 sensor circuit Low Voltage (Bank 2 Sensor 2).
Pending Fault P0113 Powertrain Intake Air Temperature Circuit High Input
I don't think changing the O2 sensor will fix it but this is why I'm here. I think the truck still ran strong when it was running. Friend said he'll junk it too if I can't find the problem soon. Hoping someone can help.
