2004 heater box rattle
LouisRosenberg
Auburn Ca
Diesel
I have a loud rattle coming from my 2004 5900 climate box. When i reach under and behind the black heater box under the dash it will stop when pressure is applied. Ive been told there is a DIY fix of cutting the box to reach the climate door bushings and replace. This would be instead of the costly labor of pulling the whole dash out and buying the climate door update kit. Does anyone know of this "cutting" option?
CharlesinGA
50 miles south of Atlanta, GA
5.9L Cummins 305 hp HO
If you have any pride in your truck, don't butcher it up. The damper doors are most likely broken and the only fix is to remove the entire heat/air box and open it up and replace the dampers.
There are several excellent videos on doing this work.
Part 1 Removal of unit from truck https://youtu.be/dBAtCnIxC2A
Part 2 Replacement of damper doors https://youtu.be/_sRvLSDALLc
Part 3 Unit re-installation in truck https://youtu.be/sN9VUyZzLKg
Part 4 Mega Cab damper replacement https://youtu.be/G-Ri_XFdREk
Door kits are available from www.BlendDoorUSA.com
Charles
L
LouisRosenberg
Auburn Ca
Diesel
I totally agree with you, I will do it the right way and thank you so much for the video connections
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If you want to see a chopped up Climate Control box
watch this
If you plan on keeping your Dodge truck for many more winters
I would choose the doors wisely
probably the best doors are
