2006 1500 trans problems
Max
I have a 2006 ram 1500 hemi and I have had this problem for a while now... For some reason when I go to start the truck and put it into drive or reverse the tran does not want to build pressure but if I put it in neutral and rev it and build pressure first its fine... but then after sitting for awhile once again does it..... has anyone else had this problem and.how did you fix it and how much did it cost..... the dealer said they.have.never seen this.
OD Ram
Tampa FL
Magnum 4.7
Sounds like you have a half manual-half automatic transmission. I'm not saying that's a thing, it's just quite odd. Have you tried taking it to any other shops besides the dealer? Also how many miles are on it?
M
Max
About to be a 100,000 at end of the week its been doing this for over a year I just want it gone my buddy works at merlins but they don't do trans work people bring them in with this problem all the time
OD Ram
Tampa FL
Magnum 4.7
That's not too bad for mileage. Mine's an '03 at 82K. And the tranny is still pretty sharp. I'd say taking it to a professional (besides dealer) would be best. Since other people have had the problem, there must be a way to fix it.
HemiLonestar
Navy Badge Coast Guard
MD
Sounds like converter drainback. It only does this when it has a chance to sit?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Never heard of this but that would be my 1st guess too along with maybe an improper fluid level problem. A new Tc, Hd shift kit, filters and sonnax should fix it.......joking aside if you avoid 2nd gear prime these trannys last a long time. What i mentioned would cost about 625 for parts and 10 hours of your time.
badblackram06
MS
Hey I have the same issue. I've had it in the dealership for this and they called it a delayed engagement. They change the internal filters and said I was good to go. It still did it but not as much. I took it back and they said everything was good and it would not hurt it if It did it again.. I gave up on them after hearing that and now with 80,000 miles it still does it almost every morning and every time I leave for work. Kind of embarrassing and annoying.
M
Max
Yes only after it sits and yea very annoying because I have to do it every morning and after work also
badblackram06
MS
I've been reading and like 03moparamman said a shift kit should fix the problem. Going to order one soon.
HemiLonestar
MD
There is supposed to be a check valve in the TC. If this fails it doesn't really hurt anything but you have to give the pump a chance to refill the TC (fluid coupling doesn't work without fluid). This usually means giving it a little more warm up time.
Herkyone23
Travis AFB, CA
I have an 05 1500 and mine does this as well. Dealer did the flush and filter change and it still does it. I've been looking for a fix for this for years.
Ramunit
There is a common issue with the check valve in the spin on filter, replace it with the new oem part number and you should be good to go. It's a fluid drain back problem.
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
good info....mine has started doing the same a few months back. However, mine does it after sitting all day at work, notice it more depending on how im parked. If the passenger side sits lower than the driver's side due to the slope of the pavement, it seems to happen the most.
stevenmicheal
