Help Support Ram Forum by donating:
2006 Megacab 1500 leaf springs
Discussion in 'Exterior' started by Nuno, Nov 12, 2018.
Sponsored By: BAK Factory Outlet
  1. Nuno
    Nuno Junior Member
    43
    14
    Nov 9, 2018
    CA
    Ram Year:
    2006
    Engine:
    Hi
    so I bought this used 2006 Megacab 1500 Hemi 4x4
    The truck looks lifted... but I can't find spacers on my front springs.
    On my rear leaf springs I do see about 2" spacer on the springs... and 4+1 leafs
    So my questions:
    - what is stock height?
    - do they come with that spacer between rear axle and springs usually?
    - 4+1 is way to hard and bumpy ride...when I only don't load the truck... so is it ok to use a standard 3+1 leaf setup from an used 1500 same year truck?
    All these questions because I need to update also my shocks and not sure what to buy... :S
  2. Nuno
    Nuno Junior Member
    43
    14
    Nov 9, 2018
    CA
    Ram Year:
    2006
    Engine:
    Hi
    So my questions:
  3. HemiLonestar
    HemiLonestar Senior Member Military
    46
    3,942
    1,548
    Jun 1, 2012
    MD
    Ram Year:
    2003
    Engine:
    You CANNOT use 1500 springs on a 1500 Megacab because the "1500" describes its capabilities. 06-08 Megacab rides on a 2500 frame with 2500 axles, suspension, 8 lug wheels, etc.
    MikeG71, Nuno and svtnos like this.
  4. CatchMyDrift11
    CatchMyDrift11 Junior Member
    37
    16
    Feb 21, 2019
    Long Island, NY
    Ram Year:
    2008 Ram 2500 MegaCab
    Engine:
    Yes. Your truck is a 2500hd. The only difference is the Megacab 1500 has 1 less leaf spring in the leaf pack. You can bolt up a 2500 spring if you want.
  5. svtnos
    svtnos Member
    35
    57
    34
    Oct 11, 2018
    Almont MI
    Ram Year:
    2008
    Engine:
    mines a 08 1500, i parked next to a qc cummins.. there were no differences between our leaf springs.. mine had the same 4 leafs and overload spring..
    CatchMyDrift11 likes this.
  6. Chrysler Cowboy
    Chrysler Cowboy Member
    18
    43
    Mar 13, 2019
    Loganville, Ga
    Ram Year:
    Engine:
    Hemi Magnum 5.7
    Ok, with your "lift" question,
    1) all newer model trucks come with a slight rake(higher in the rear than in front) not usually as much as 2 inches though which brings me to my second point
    2) you most likely have your torsion bars cranked up
  7. svtnos
    svtnos Member
    35
    57
    34
    Oct 11, 2018
    Almont MI
    Ram Year:
    2008
    Engine:
    uh torsion bars ? not on these trucks..
  8. Chrysler Cowboy
    18
    43
    Mar 13, 2019
    Loganville, Ga
    Ram Year:
    Engine:
    Hemi Magnum 5.7
    Do you have coils in front?
  9. svtnos
    svtnos Member
    35
    57
    34
    Oct 11, 2018
    Almont MI
    Ram Year:
    2008
    Engine:
    All 2500/3500 and 1500 megacabs which are 2500s have a solid axle with coil springs ..
  10. Chrysler Cowboy
    18
    43
    Mar 13, 2019
    Loganville, Ga
    Ram Year:
    Engine:
    Hemi Magnum 5.7
    Ah ok
Share This Page
