2008 Dodge Ram 1500 , where is the horn!?
Anthonykyle
Montana
I have a 2008 1500, the horn has started going off randomly. No horn fuse. From my reading it's probably the tipm. The problem... I disconnected the battery for the time being so the horn doesn't go off in the middle of the night, I was going to disconnect the horn but I can't find it. I connect the battery and the horn stays on constantly now. I need to disconnect the horn but like I said, I can't find it. Any one have answers? Thanks
crazykid1994
Drivers side front quarter panel. Pull out the wheel liner
Edit: is the horn button stuck or did the relay go bad? Horn should have its own relay unless they integrated it into the tipm. Then there should still be a fuse for it.
A
Anthonykyle
Montana
Thank you, the horn button didn't get stuck. It doesn't have it's own relay unless I mistaken. I believe it's integrated into the tipm from my reading. It was just going off randomly, now since I unhooked the battery..anytime I hook the battery up it just goes off and stays on.
