jws123
2010 Ram 1500 5.7 4x4 I bought this truck as a project a while back rebuilt motor ect it was used and abused previous owner ran it into the ground basically. It has been a royal pain in my ****!! one thing after another had a front end clunk/noise when driving/turning. I finally found out the pass side lower ball joint Is spinning inside the lower control arm where it presses in even with a new ball joint it just spins/flops around it wore away the metal. Does anyone have any suggestions should I try to weld it in? its aluminum so not sure if it would work I really don't want to replace the whole control arm because I know every bolt is going to snap very rusty just trying to see if anyone had any suggestions before I just sell it as is.
