2010 RAM 1500 spark plugs question
tincup
DFW, TX
Hey guys, new to the forum. I have a 2010 with the 5.7L hemi, about 134k miles. It's time for me to replace the spark plugs. I've seen conflicting opinions on what the best brand, etc. is. What model no. and brand do I need?
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
NGK is what MOPAR uses. Just did mine a couple months ago. Moe’s has them here.
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Those are the ones. I recommend checking the gap on each one. .043 is what I used. Get some anti seize on the threads and dialectic grease in the boots and you are golden!
Burla
2010 Hemi Reg Cab 4x4
Yeah, you have to use those and more importantly replace every 30k. Post up some pics of those old plugs, I might consider coil packs with that much mileage as well. If you put back a different coil pack, you can use 100k plugs, do some research.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
Are those the standard NGK plugs? Not Iridium or Platinum, right?
Geoffrey Moreland
Buckeye, Arizona
I replaced mine 3 months ago with NGK, no issues reported
Just watch those coil boots, and I think the Hemi has 2 plugs per cylinder
thaimex
San Antonio, Texas
Hello guys,
just a thought of what I’ve done before:
I’ve changed the spark plugs almost 2 years ago on my 2010 Ram 1500 5.7. I worked at Autozone back then and I looked into getting the best plugs for my truck. I looked for longevity, durability of the plug and how often do I changed them. Well, I ended up buying the Denso Double Iridium(around $9.50 each) plugs and they are good for over 100,000 miles.it’s been almost 2 years and way over 100,000 miles that I replaced them and the truck has not given me any issues at all. Love the way it runs smooth and quite. I’m sticking with these same plugs again cause now I see how durable they really are and it’s time to change them out after almost 2 years are coming up since I last change them out. I spent about $150 on plugs alone but I guess it’s not bad when they last this long. We’ve been to New Mexico, Florida and all over Texas and NO ISSUES AT ALL. But yet again, I’ve been working on cars since I was 15 and love my Ram truck.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Hello guys,
Go all the way - spend some mo' money and go with the latest - ruthenium! lol Then you can get 1/4 million miles and better spark, too.
In all seriousness, I suppose there is some kind of market for these, but probably only the Japanese companies could come up with something this extreme. American corporations won't anymore.
gixxer
SK Canada
4.7L
You actually want to put dielectric grease on the threads. Its to help electrical conductivity as the threaded area acts as a ground. Also, will help with keeping moisture out of the cylinder.
Texram155
i have done 3 sets with ngk and no issue. if the coils were not so much more plus the cost of iridium plugs i would make the switch
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Check out;
https://www.rockauto.com/en/catalog...ckup,5.7l+v8,1445018,ignition,spark+plug,7212
NGK 92174 {#05149177AB, LZFR5C11, SPLZFR5C11} Standard
Dual Plug; Gap 0.044"; Actual FCA OE NICKEL plug (30,000 mi/48,000 km interval).
$ 3.01 each
NOTE: FCA OES now recommends IRIDIUM extended service plug.
NGK 4469 {#BY481LFR5A, LFR5AIX11, MZ602090} Iridium IX
$ 6.33 each
When you go into an auto parts store the number after the NGK will be the number on the box; ie NGK 9217 or NGK 4469
The number on the spark plug likely may be either LZFR5C11 or LFR5AIX11
If the spark plugs are bought at the dealership it will likely have a SP before the number
SP = Spark Plug
