My 2010 Ram 1500 4.7 TRX4 has the NVG243 transfer case in it. When I was using it in conjunction with a little Bobcat backhoe the pull the stump out in front of the house on Thursday my neighbor made an observation that I wasn't aware of.
In 4x4 High all four tires were spinning in reverse on some of the attempts as we found the various roots to cut off.
In 4x4 Low, however only the rear tires were spinning. This is an issue that I am glad to know about, if I am on a steep mountain road, like the poweline road on Mt Charleston I usually use 4 low to crawl up the hill rather that tear up the dirt like so many do. Without 4 low on this road I will have to use 4 high which will spin more.
I Need to figure out why only 4 low would have the problem and what I might need todo to fix it.
Sometine this week, I will be changing the fluid on the transfer. At which time I may know more symptoms.
Any thoughts on what it might be?
