Jory
Sorry I didn't know where to post this.
245000km a while ago my mechanic said he he noticed a high frequency vibration coming from the drive shaft after he did the u joints. And I recently moved found another good mechanic, he notice a grinding nose from the dif when going slow in the parking lot when he did the calipers. I thought it was cause the one caliper was seizing. Sounds like the break rotor is grinding. She said it's probably your dif bearings and recommended a guy who just does difs. That said the dodges eat dif bearings. Calling around just pricing it out. One shop, said it if making nose it probably got filings in it and has pitted the ring gear and the nose will still be there after the bearing as said to just get a rear axel from the wreckers. Yeah, like I going to do that without even seeing the truck. Lol. What's involved with changing those bearings. Does the ring and pinion have to come out. I am assuming they do. If so then it wouldn't cost extra labour to put a new ring and pinion in it. What do you guys think. I am have the fluid changed in a couple weeks. Not taking the cover off. Just for filings and put royal purple in it. And just see if there is an improvement. Figure good place to start fir lil cost. Will be lucky if I run 3 tanks of gas through it this winter. Will address the diff in the spring. Any advice or experiences would be appreciated. Thank you.
