2011 Ram 1500 Air Bag Light After a/c Evap Replacement
jws123
nj
2011 Ram 1500 Air Bag Light is on I had the dash out today to replace the Ac evaporator Been chasing this for hours cant find what i did here is the code I even checked the wire on lower pass side i forgot that one when i did heater core.
Any help much appreciated.
Fast69Mopar
Did you have the seats out of the truck? Inspect the connectors under the seats and make sure they are tight and properly inserted together.
I have seen this issue a few times. The last two trucks that exhibited this exact concern I had to replace the TIPM on both of them.
jws123
jws123
nj
I got lucky after messing with it again nearly tearing it half apart I un hooked the main plug under drivers side clicked it back together few times light and code are gone..
Fast69Mopar
I had a feeling that it was a connector under the seat. Good job.
jws123
jws123
nj
Was the big connector under the dash drivers side near brake petal main one that comes in i never took the seats out.
Fast69Mopar
It's pretty common for this to happen after moving the instrument panel. I've had several where I had to go back and reseat connectors.
